At the weekend I wanted to eliminate my equipment just before the end of the event. CDJ400 ran right side on deck 2 and the left CDJ400 on DECK 1 was free. I wanted the free player degrade ... after I pulled the USB plug, fell silent and the current player stopped playing. After I plugged in the USB connector again, the previously current CDJ for Player 1. the decks were reversed. but the worst that the player 2 stopped the playback.
Can I log off the not running player before?
Last Beta build 2195
OSX Mavericks
OSX Mavericks
geposted Tue 14 Apr 15 @ 9:57 am
Why would you do that (disconnect a running controller or audio interface while VDJ is active)?
You wouldn't try and change your tyre while driving, would you? :-)
geposted Tue 14 Apr 15 @ 12:12 pm
I understand your surprise, but think about this, pulling a usb cable isn't the same as pulling a audio cable. As soon as you pulled that cable, deck 2 suddenly became the only deck connected, so it was deck 1, so if you want to start to pack up on the last track make sure it's deck 2 that you disconnect.
geposted Tue 14 Apr 15 @ 12:20 pm
Since at that point there would be no controller controlling deck 2, that doesn't explain why the deck stopped playing though.
geposted Tue 14 Apr 15 @ 10:53 pm
Ok, i have no chance to Say left Player is deck 1 and right Player is deck 2 ???
I know what Young mean guys... I think about it
geposted Wed 15 Apr 15 @ 4:51 pm
In Options->Controllers, you can select a deck for each controller instead of leaving it on 'Automatic'
geposted Wed 15 Apr 15 @ 10:55 pm
You can not disconnect one player because both players create one sound card
geposted Thu 16 Apr 15 @ 9:10 am
As above.
I've had the same thing happen to me with 2000s/2000nxs.
geposted Thu 16 Apr 15 @ 2:31 pm
could this be related to using them as a sound card and u unplug the sound card = no sound ?
geposted Thu 16 Apr 15 @ 3:05 pm
Exactly that.
geposted Thu 16 Apr 15 @ 11:07 pm
