Hi I have virtualdj 8 updated and I can't make rewire be show on the dropbox I tried many times with different sound cards even with the internal one on my mac and my windows desktop I even tried in my friends pc and nothing . . please help, I have macbook pro retina 8 gigs ram 250gb hard drive, vdj8 and ableton live 9 lite (my friend have live 9 suite)
geposted Thu 16 Apr 15 @ 8:45 am
Are you opening the SW in the right order, (V8 First)
You are using 32b version of Ableton?
geposted Thu 16 Apr 15 @ 8:51 am
I did everything by the book, even reinstall live, I am running Mac and everything is the same (64 bits), I installed sound flower and I can see it but I can't see rewire on the drop list, any help please?
geposted Fri 01 May 15 @ 3:57 pm
You need to use 32b software.
geposted Fri 01 May 15 @ 4:44 pm
On mac, you would need 64-bit software.
The problem here is that at the moment, rewire on mac is not yet supported.
geposted Sat 02 May 15 @ 12:33 am
rewire is supported on mac, I called to Ableton, amazingly they are more worried for their customers than Virtual dj, I followed all the instructions they provided, but I haven't heard anything from virtual dj, zip zero, nada. anyway I think if I want to use ableton live during my mixes I should buy serato sl1
geposted Thu 28 May 15 @ 7:12 am
You heard from VirtualDJ right above your post - the CTO no less - rewire is not currently supported in the Mac version of VDJ.
geposted Thu 28 May 15 @ 8:49 am
I have the same isuue.
Is there any intention from Virtual Dj to add ReWire to Mac version of VDJ8?
As long as I know I have paid the same amount of money than Wondows users.
Thank you very much.
geposted Tue 04 Aug 15 @ 6:02 am
