Topic: scripts visibly cut, low priority
As you can see from the pic, lengthy scripts are visibly cut in the controller section and the text box appears blank, the scripts work, operationally it isn't a problem but it's still a bug, just not an important one.
geposted Sat 18 Apr 15 @ 6:53 am
Did you try to resize the window after extendig the column for the script?
Maybe its just a redraw issue.
geposted Mon 20 Apr 15 @ 3:22 am
When I resize the window the column width resets.
geposted Mon 20 Apr 15 @ 3:33 am
