Just noticed that load security is not working. I've tested settings and get no response.
geposted Sat 18 Apr 15 @ 3:46 pm
Working on the current beta (2206) are you sure it wasn't set to no?
geposted Sat 18 Apr 15 @ 4:00 pm
Which skin are you using?
There have been some issues where skins have multiple drop zones bypassing security settings.
geposted Sun 19 Apr 15 @ 3:05 am
And it will only work if the volume fader of the deck is up.
geposted Mon 20 Apr 15 @ 3:20 am
Using Altern8 skin. It worked one time Saturday, so 9 times out of 10 it does not work when loading a track on a deck already playing.
geposted Mon 20 Apr 15 @ 10:09 am
