Trying to apply multiple effects (audio and video) at once. Using the four deck skin. I see an option for multiple effects on the two deck skin. Is there a way to do this with the four deck skin?
Using the text video effect over video clips loaded in the sample bank. Text will only show if the sample is not full brightness. Tried activating the sample, then text. Aldo did the inverse. Possibility for an always on top setting? Same issue with title.
geposted Sat 18 Apr 15 @ 9:26 pm
multifx
Click the word "Slot 1"
http://pasteboard.co/2FJZ5oDD.png
If that doesn't work you need to get the updated skin
http://www.virtualdj.com/documents/Skins/VirtualDJ%208.zip
geposted Sat 18 Apr 15 @ 10:32 pm
New skin fixed that. Thanks.
Any advice on Text always on top?
geposted Fri 24 Apr 15 @ 4:57 pm
Don't know really, have you tried text on the master?
geposted Sat 25 Apr 15 @ 6:02 am
No luck.
geposted Sat 25 Apr 15 @ 3:28 pm
