Is there a way to make a filter folder display the tracks that you have played (in the past) after the track you are currently playing?
geposted Sun 19 Apr 15 @ 5:29 pm
No. I have for this script in PHP code compiled into exe file, based on tracklist.txt data. It works perfectly :) It is a great idea built this directly into VDJ as filter. Maybe in some next build...
geposted Sun 19 Apr 15 @ 9:43 pm
geposted Mon 20 Apr 15 @ 2:56 am
