virtual dj 7 serial, but I can't get my serial 8 not for serial. Please help
djcem_77@hotmail.com
geposted Wed 22 Apr 15 @ 4:32 am
Version 8 does not use any serial number. Just login with username and password to activate.
You need a serial only if you buy a Hardware which comes with a LE serial number to activate.
Greets, Heiko
Greets, Heiko
geposted Wed 22 Apr 15 @ 4:55 am
I have the same serial for 7, but not mercenary can't help serial serial 8 e
geposted Wed 22 Apr 15 @ 5:05 am
7 for I have 8 I can't get to the mercenary serial
geposted Wed 22 Apr 15 @ 5:07 am
You need to enter your username and password to activate. There is no serial number.
(Do you need some kind of online translator ? I don't understand what you are speaking of.)
geposted Wed 22 Apr 15 @ 5:10 am
Dear jakovski , how can I activate my VJD 8 without internet conection? Can you help me? Thanx!!
geposted Wed 10 Jun 15 @ 9:51 pm
If there is no way to access the internet one time for the activation, then you can contact support and explain your situation to obtain a key file.
geposted Wed 10 Jun 15 @ 10:55 pm
Thank you!!
geposted Sun 14 Jun 15 @ 9:03 pm
