Topic: Load Security Issue
Hi,
Using a DDJ SZ, when I click on the load button when a song is playing on player 2, i get prompted by load security. On player 1 on the other hand I don't.
I tried this with the VDJ skin as well and can duplicate it.
geposted Wed 22 Apr 15 @ 5:17 pm
Load security only works on a deck playing live, to protect you from unwanted results ;)
So if the other deck is MasterDeck the load security wont work on the Slave.
geposted Wed 22 Apr 15 @ 7:27 pm
