Topic: Pad Question
Is there a way to mak a sampler button stop the current sample and play the one associated its designated button.
If I have sampler 1 engaged, instead of hitting sampler 1 to make it stop, I hit sampler button 2 to stop 1 and play 2
geposted Wed 22 Apr 15 @ 5:55 pm
You just need to have both samples assigned to the same Sampler Group and the buttons assigned as sampler_pad x
geposted Wed 22 Apr 15 @ 7:30 pm
So when I hit pad 2 or 3 what ever current sample that is playing from the same group will stop and the pad I hit will be the only be playing?
geposted Wed 22 Apr 15 @ 8:29 pm
yep that's how groups work.
geposted Wed 22 Apr 15 @ 8:37 pm
