Hi Fellow DJ's, yet another Tag Edit question. Attached you'll see the TE's from my pc and laptop, there is a difference. The pc one has the tag up arrows beneath certain fields and the Write Tag at the bottom(marked in red). The laptop one has none of these. This is something I've been wondering about for ages but never remembered to mention it till now. Anyone know why this is. Both are current beta builds 2206.971 and I'm using FRUiT's skin. When I change skin to the default - they still have the same differences and thats with or without Aero. Both machines running Windows 7 ultimate
PC TE
Laptop TE
PC TE
Laptop TE
geposted Sun 26 Apr 15 @ 7:12 pm
Your laptop is set to automatically write to tags, you desktop isn't, hence your dt install is showing db entries and tags also options to write to tag.
It's in options.
It's in options.
geposted Sun 26 Apr 15 @ 7:18 pm
It's in options.
It's in options.
Thanks Locodog - You Da Man as always :)
geposted Sun 26 Apr 15 @ 7:22 pm
