Hey guys,
Is there a way i can know if my bass is killed on a deck in Virtual DJ 8 ? I know on 7 the word "Low" , "Med", or "High" would illuminate letting me know that my bass is killed. Is there a way I can get the same experience in VDJ8 ? Thanks
geposted Mon 27 Apr 15 @ 7:24 pm
These indicators have been recently added to the default skins. The updated skins will be installed with the currently available build, but not with the automatic updates.
So instead of re-installing VirtualDJ, simply replace the VirtualDj 8.zip file in Documents/VirtualDJ/skins with the file you will find here
geposted Mon 27 Apr 15 @ 9:32 pm
Thanks bro, That worked !!!
geposted Tue 28 Apr 15 @ 2:18 am
BTW there's no need for you to rewrite or quote everything posted in the previous message. It's obvious who you're replying to!
geposted Wed 29 Apr 15 @ 1:52 pm
