VDJ8 Manual says following " iTunes Playlists will be displayed by default following the offered order from iTunes. You may rearrange the order of your Playlists by drag and drop an iTunes Playlist to any position inside the iTunes root folder." I did rearrange the order of Playlist but as soon as I quit VDJ and restart the order is set back to Itunes standerd. It doesn't keep the drag and drop order in VDJ?
geposted Tue 28 Apr 15 @ 10:02 pm
