Topic: Scratch Wave (Bug)..............
My scratch wave now looks like this,
Nothing has changed on my Mac. Haven't tried my PC. And it doesn't matter what skin I choose, everyone looks like this. Latest beta build but Ill go back and see when this started.
geposted Wed 29 Apr 15 @ 6:11 pm
disable HW acceleration? Should be set to no.
geposted Wed 29 Apr 15 @ 6:23 pm
I did that and NO wave shows. But its fixed now, I went and switched my ZERO DB from -3 back to 0.75 and then the waves were fixed???
I switched because I noticed that my levels stayed in the red and the limiter was always on. Haven't changed that setting since a few updates before so Im not sure whats going.
geposted Wed 29 Apr 15 @ 6:30 pm
Typing -3 and choosing -3db from the drop down menu are different actions.
Most likely you typed -3 manually
geposted Thu 30 Apr 15 @ 4:00 am
Yeah could of been what happened but I don't think I typed it in. I remember seeing a thread and someone asked what 0.75 would be and someone else told them -3 so I'm pretty sure I selected from the drop down.....
Either way it's fixed now and I also see the newest beta has fixed something with the DB's.
geposted Thu 30 Apr 15 @ 2:11 pm
