Topic: POI loops don't seem to quantize
Not a problem for me, but I can't think of a good reason why they shouldn't.
geposted Fri 01 May 15 @ 6:03 pm
Probably because Loops dont quantize either at the moment
geposted Fri 01 May 15 @ 6:43 pm
Yeah thinking about it, it is tricky to catch the loop cue, with quantize on, early is possible but late is tricky, unless of course the system is primed
cue 2 is a loop cue, if HC 2 is pressed jump keep sync, get position, adopt the loop of the cue and a sneaky loop move forwards or back to the cue
In all honesty really how easy does need to be, maybe sync by ear is an old world skill but a prerequisite should at least be a modicum of timing
geposted Fri 01 May 15 @ 7:23 pm
