Topic: Ctrl|Shift for dragging folders
There's still a confusion with, Ctrl|Shift for dragging folders currently if I want to nest a folder I use Ctrl+drag, shouldn't this follow the file (and windows) standard, and be Shift+drag?
geposted Tue 05 May 15 @ 12:13 am
