Version 2231.975
I just noticed a annoying bug. When you drag a song to another position inside a playlist it becomes unavailable to keyboard controller actions.
Example: click a song in a playlist, drag it up or down some songs. Then an keyboard controller action like "load" does not work on that song, unless you select another song and then the first one again.
I also noticed that after dragging a song, and you leave it selected, you cannot move up and down through your playlist with the arrow up and down buttons. The song selection jumps around.
geposted Tue 05 May 15 @ 2:12 am
Nope, tested every thng you said in both the files space and the sidelist space and everything checks out fine.
The last bit, "...Jumps around" it goes to the next entry had the file not moved, only once.
geposted Tue 05 May 15 @ 2:27 am
Maybe I should have mentioned that I tested it only in the playlist area of automix (on or off does not matter). There it is definitely happening as I described.
geposted Tue 05 May 15 @ 3:12 am
I can reproduce that.
Steps to reproduce:
- Load something into automix list
- Drag a song to another possition
- use the keyboard up or down arrow
- the selection cursor jumps to the track after the next track of the previous position of the move file.
In other words, what the cursor should do after moving the track is, (assuming the down arrow is pressed) select the next track under the moved track in it NEW location.
What actually happens is, the next + 1 track is selected of the moved tracks OLD position.
So two bugs:
1. Selection is made at old position
2. Selection skips 1 track and selects x+2 instead of x+1
geposted Tue 05 May 15 @ 4:10 am
