Forum: Old versions
Topic: Crashlog?
I am the one who likes to get to the bottom of weird behaviour of my PC VDJ system.
Yesterday I had a strange crash of the entire Windows that I would know what caused it.
I had VDJ8 on for about one hour , no audio , just "standby" - after a while I noticed that the PC screen was black and I noticed the PC had shut itself off.
When starting up the PC again, windows 7 went into the start-up options and I choose "Start windows normally".
Well, my question is: Does windows save any kind of log or report of what caused it to go down?
geposted Wed 06 May 15 @ 1:25 pm
blckjckPRO InfinityMember since 2008
Depending on what type of error it was would depend on where the error would be kept.
First thing I would do is check the event viewer.
geposted Wed 06 May 15 @ 9:51 pm
i could not find the event viewer. Where is it stored?
geposted Wed 06 May 15 @ 11:37 pm
1. Open the Start Menu, type eventvwr.msc, and press Enter.
2. If you are logged in as an administrator and prompted by UAC, then click on Yes.
3. In the left pane, click on an event log to see it's events listed at the top of the middle pane.
4. If you like, you could also right click on an event log in the left pane for more options to use. For example, to Filter Current Log or Find a specific event ID number listed in the middle pane.
geposted Thu 07 May 15 @ 7:11 am
Thanks!!
geposted Thu 07 May 15 @ 7:23 am
