Hi all,
just installed Windows 8.1 and downloaded the latest version of VDJ, now when i run the program all i see is a small window in the top left corner of my screen.. and... some weird message about i can only use my controller for `10 mins.. errr i thought my subs enabled me to use this software with my controller without exception?
*Edit* Windows smartscreen stops me install VDJ5 and 7..
geposted Wed 06 May 15 @ 5:37 pm
First, you can still install v5 and v7 if smartscreen pops up.
There should be a Link reading "more informations" or something like that. KLick on it and you will get a button to execute the install file.
For v8 I think you should update your video drivers if its a clean install of win 8.1
geposted Thu 07 May 15 @ 2:25 am
hmm why should i install version5... that's older than the version I had installed previously?
There are no drivers available for my Video card for 8.1, had this issue with Win7 also, it just blue screens if i try and install a driver that says it's for my video card, which is quite old :( i've hated ATI cards with a passion since Win 3.1, I'll see if i can install V7
geposted Thu 07 May 15 @ 3:14 pm
dj_julest wrote :
Hi all,
You have to login to VDJ to get rid of the 10 minutes limitation of controller use.
geposted Fri 08 May 15 @ 2:41 am
What is the model of your mainboard and video card?
Because in your first post you wrote this:
"*Edit* Windows smartscreen stops me install VDJ5 and 7.. "
And that's why I said it is still possible.
geposted Fri 08 May 15 @ 5:45 am
dj_julest wrote :
Hi all,
Thanks, that's sorted now after I logged in :)
geposted Sat 09 May 15 @ 5:04 am
I meant VDJ5 but anyway thanks for the help I'm now back up and running on VDJ7 until i buy a new video card that has drivers for Windows 8.1
geposted Sat 09 May 15 @ 5:06 am
