Topic: Piece of translation missing
Because the whole grooveshark thing, I became curious about the audio Subcription plan. I tried a netsearch to see what's happening and how it works.
Then I saw a message telling me about the subscription I need, but a few lines are still in English. Maybe the most important lines since it's telling about the 30 secs only and what the prices are.
Just to let you know...
geposted Thu 07 May 15 @ 3:55 am
In case you want to change...
Translation into Dutch:
Zonder een abonnement kunt u maar 30 sec van dit nummer spelen.
Als u zich wil abonneren, dan kost een Content Unlimited Audio plan maar $9,99/pmaand.
geposted Thu 07 May 15 @ 4:01 am
The translation appears to be in place.
Keep in mind that the language files are only updated by the installer, so to ensure you are using the latest version of the language files, you should try to install VDJ again using the installer.
geposted Thu 07 May 15 @ 6:12 am
Thanks for your reply.
Well.. I don't mind a little bit English and VDJ works perfect for me, so I'm not going to try to reinstall ;)
But now I know where it comes from.
geposted Thu 07 May 15 @ 6:15 am
You can always change it yourself.
It's in VDJ/Languages/<language>.xml
geposted Thu 07 May 15 @ 6:48 am
Thank you for your info and what do I see?
In the Dutch XML is the Dutch translation of that rules! The spelling/grammar sucks, but it is in Dutch. So why do I get English text instead?
geposted Thu 07 May 15 @ 8:48 am
Maybe the IfYouWantToSubscribe key is set more than once in the xml by mistake?
geposted Fri 08 May 15 @ 5:56 am
Nope
geposted Fri 08 May 15 @ 6:10 am
