Hello,
sry but my English is not so good.
I have the following problem : I want to make settings under the Options tab .
Unfortunately, the screen content is empty . When I go with the mouse on the blank screen , and texts are displayed by clicking the menus are partially visible .
My System:
Lenovo Y50-70
Windows 8.1 x64 ,Intel I7 16 GB Ram NVIDIA GeForce GTX860M und Intel HD 4600
My System:
Lenovo Y50-70
geposted Fri 08 May 15 @ 3:02 am
This is a known issue with high resolution displays, what is your screen resolution?
geposted Fri 08 May 15 @ 4:55 am
He created a support ticket.
I think further communication is handled that way.
geposted Fri 08 May 15 @ 5:42 am
I had opend a Suport ticket but they answerd i shoud post this in the Bug forum
geposted Fri 08 May 15 @ 7:06 am
My screen Resolution is 3840 x 2160
geposted Fri 08 May 15 @ 7:08 am
have my screen resolution to 2048 x 1536 changed
vdj is run but it"s to big my screen and the icons
is possible this fixed at next update?
geposted Fri 08 May 15 @ 7:22 am
The standard skin resolution in VDJ 8 is 1920x1080 so it will of course look "too big" if you have VDJ maximised.
Try running VDJ windowed and drag the edge to make it smaller.
geposted Sat 09 May 15 @ 4:04 am
