As the title suggests, every now and then the BPM's and cue points disappear. Technical support have been little to no help at all. I'm using VDJ on a MacBook. I'm loading the tracks straight from an iTunes folder. Does anybody think this could be a reason?
geposted Wed 13 May 15 @ 3:21 pm
Are you moving stuff/ renaming stuff with something other than V8?
geposted Wed 13 May 15 @ 4:42 pm
Does it happen to all of your files or just some files?
What is the file system of your harddrive?
geposted Fri 15 May 15 @ 4:04 am
This has been an ongoing issue since I started using vdj6, the best advise is always back up the DB. I thought the bug got fixed with 8, but it just happened to me last week.
geposted Wed 20 May 15 @ 4:55 pm
I'm so sorry but there can't be a bug in general because out there are so many user without this problem.
Myself included.
Most the time when a file show up as unscanned, was it moved or edited by the user.
For example:
When you move a track from folder A to Folder B, without using the VDJ browser -> You will loose the DB relevant details like BPM etc.
When you change inside iTunes the filename or also the destination of a file .. -> You will loose the DB relevant details like BPM etc.
Please keep in mind.
Inside the database the exact path details of a track is stored and so if you change somthing there it will fail on VDj side.
Volumename/Music/Example/Michael_Jackson - Beat It.mp3
When you now change on iTunes side just the filename to Volumename/Music/Example/Michael Jackson - Beat It.mp3 - It will show as unscanned!
I'm so sorry but i really believe there is just a wrong acting on your side then a software issue on our side.
If you use a external harddrive, please also check these drives are formatted with exFat.
In case you use it also on a Windows system.
Myself included.
For example:
geposted Thu 21 May 15 @ 7:19 am
