Forum: Old versions
Topic: Help me!
I have bought the Numark mixtrack 2 which comes with virtual DJ karaoke, video and audio. However, reading the comments on this site which are saying I would have to upgrade to the Virtual DJ pro for the decks to work without cutting out, is this true or would I be able to install the software which comes with the mixtrack 2 and use them as normal and works fully instead of stopping every 10 minutes?
geposted Mon 18 May 15 @ 6:13 am
Cripes man, simmer down, yes you can use LE (the bundled software) LE is the bare minimum version of VDJ to operate every dial and button, but LE excludes a few things,
Remapping, can't be done with LE
Several of the editors are omitted from LE
LE does not permit use as a paid dj.
If you're going to be doing paid gigs, you must have a pro licence or subscription
If you want to use all the V8 features but you're not a paid dj you want a controller licence (AKA plus licence)
If you don't want to pay anything then LE (bundled software) will run your device.
geposted Mon 18 May 15 @ 6:29 am
Also register your LE serial number and you may get a small reduction on upgrade purchases, that and you get a few forum privileges too.
geposted Mon 18 May 15 @ 6:48 am
