Topic: A bug that happenens every time...
DJAVIPPRO (OEM)Member since 2016
Build 2265 mac version
Every time i press config and options i get this message
What is it ?
-when removing a folder from favorite the software crashes
Os x 10.7.5
Mbp 13" i7 2.9ghz 8gb
geposted Tue 19 May 15 @ 5:01 pm
someone ?
geposted Wed 20 May 15 @ 3:15 pm
Haui70PRO InfinitySenior staffMember since 2008
I'm sorry, but i have no idea, but maybe it is related with the skin and/or the OSX you use?
Do you have a chance to try it on a similar Mac with 10.9 or 10.10?
If not i would try to do a "real" clean inst.
- Delete the main Virtual DJ program from Applications (V7 & V8 ;-)
- Delete the Virtual DJ folder in Document (Backup the folder onto a USB stick)
- Download & use the following tool.
http://www.virtualdj.com/addons/15709/VDJ_Plist_Cleaner__mac_osx_.html
- Empty the trash
- Download and install only the VDJ version from here and try it clean, without added effects, skins etc.
http://www.virtualdj.com/download/index.html
Does it work now?
If yes, please close VDJ and restore the VirtualDJ folder and tr yit again.
Does it work again?
geposted Thu 21 May 15 @ 5:38 am
