Topic: Karaoke Title Screen Graphics Cropped [SOLVED]
Ever since 2245 update my karaoke title graphics are cropped at the sides. If I revert back to an ealier release it's fine. The actual song words are ok just the titles. I can email video if required.
geposted Wed 20 May 15 @ 8:36 am
geposted Wed 20 May 15 @ 10:18 am
update to the newest version.
geposted Thu 21 May 15 @ 12:08 pm
No change
geposted Sun 24 May 15 @ 1:36 pm
I downloaded some Karaoke and it seems like only SUNFLY brand is doing what you are describing.
I did however find a FIX and what I did was unzip and re-zip ( I use KJ Filemanager) but you can use any and make sure to zip it standard.
geposted Sun 24 May 15 @ 8:00 pm
Could any of you send me one of the karaoke files that shows this problem?
geposted Tue 26 May 15 @ 3:38 am
geposted Tue 26 May 15 @ 10:25 am
It was quite the opposite here. When i loaded the zip file, everything was displayed properly.
Then i extracted the files, zipped with Winrar and then i could reproduce what the OP reported.
geposted Tue 26 May 15 @ 10:56 am
Loading the zip file shows correctly but when you play it, it will crop borders before it goes into the lyrics part.
geposted Tue 26 May 15 @ 1:14 pm
Has anyone found an answer to this yet.
geposted Sun 31 May 15 @ 8:38 am
The problem has been found, should be fixed soon.
Excellent
geposted Sun 31 May 15 @ 9:09 am
Had same issue as you Tim on Friday evening (Zoom track) - will keep an eye on this thread - hopefully will be next build release.
geposted Sun 31 May 15 @ 12:10 pm
VDJ RonPRO InfinityMember since 2010
I've had no problems, I wonder what version I'm running?
What do the zoom, bars, and crop VDJ8 advanced video option do, if anything?
geposted Wed 03 Jun 15 @ 7:12 pm
Tim - this should be all fixed now - mine is :)
geposted Fri 19 Jun 15 @ 5:50 am
