i got the scratching feeling tighter than Serato
alll that im missing is My fillter roll on my fillter knobs
geposted Fri 29 May 15 @ 8:25 pm
Describe filter roll.
geposted Sat 30 May 15 @ 2:40 am
geposted Sat 30 May 15 @ 2:46 am
thats the one :)
geposted Sat 30 May 15 @ 6:04 am
filter & param_smaller 10% ? loop 0.125 ? nothing : loop 0.125 : param_smaller 20% ? loop 0.25 ? nothing : loop 0.25 : param_smaller 30% ? loop 0.5 ? nothing : loop 0.5 : param_smaller 40% ? loop 1 ? nothing : loop 1 : param_smaller 60% ? loop ? loop 0 & slip_mode 0 : slip_mode 1 : param_smaller 70% ? loop 1 ? nothing : loop 1 : param_smaller 80% ? loop 0.5 ? nothing : loop 0.5 : param_smaller 90% ? loop 0.25 ? nothing : loop 0.25 : loop 0.125 ? nothing : loop 0.125
geposted Sat 30 May 15 @ 9:13 am
Unless I'm missing something here, the NV already has filter roll, just hit the button left of the right platter that says "filter roll" to activate then turn filter knob to engage. Hit the button one more time so the light blinks, and whatever effect you have in slot 1 will engage with the filter.
geposted Sat 30 May 15 @ 10:14 am
Any interest as this as a plugin?
geposted Sat 30 May 15 @ 3:11 pm
That would nice and could it be simple, meaning, I press a button to turn it on the turn 1 parameter knob to adjust loop/filter.
Not that it matters but if an effect has more then 2 parameters I just delete off my machines. Yes some people like to control every aspect of a plugin but in my opinion that just gets complicated and not really useful during a live session.
Simple isn't always a bad thing.
But to answer your question, Yes Loco that would be cool.
geposted Sat 30 May 15 @ 3:40 pm
I try to keep my plugins with param 1 being the main one and other dials as set once type of things.
I think this will have 2 dials, 1 as you say the main one and the other will pick 4 different loop patterns, standard, funk, standard&funk, mental.
geposted Sat 30 May 15 @ 3:52 pm
That's what I like to hear!! Looking forward to seeing what you come up with.
Thanks!!
Thanks!!
geposted Sat 30 May 15 @ 3:53 pm
A bit of info needed what is the standard loop pattern?, I guessed for 1,0.5,0.25,0.125 is this right or does it go further? (1/16ths = 0.06125)
geposted Sat 30 May 15 @ 6:13 pm
it does not seem to work in vdj . other than that everything seems real nice even got my line curve adjustment down where i want it . got to say vdj has come along way
geposted Sun 31 May 15 @ 2:17 am
i would :)
Interested
geposted Tue 02 Jun 15 @ 12:48 am
If the Filter Roll mode of the NV doesnt work as expected, can you check if the Slicer Effect is enabled from the FX drop down list ?
geposted Tue 02 Jun 15 @ 6:05 am
i dont know what i did but it seems to work just not like serato as the track acts like its in slip mode
btw thanks everyone here for the help the last time i used vdj was in 2008 when i switch to mixvibes
geposted Tue 02 Jun 15 @ 10:25 pm
I thought slip mode would be the way you wanted it.
It's how I'm writing the plugin.
geposted Tue 02 Jun 15 @ 10:29 pm
Thats why its called Filter Roll and not Filter Loop ;)
geposted Tue 02 Jun 15 @ 10:33 pm
A bit of feedback required, I've got a simple version working here but it doesn't feel right
Imagine;
I've got my dial and it controls the filter
if dial < 10% loop 1/16
if dial < 20% loop 1/8
if dial < 30% loop 1/4
if dial < 40% loop 1/2
if dial between 40-60% loop 1
if dial < 70% loop 1/2
if dial < 80% loop 1/4
if dial < 90% loop 1/8
if dial > 90% loop 1/16
If just doesn't feel right, I think I should tighten the bunch in the middle and as extremes of filtering are not that audible.
The other thing is I think you should be able to progress the track (if you want) so if dial = 0% or 100%, loop goes off until the dial goes between 10-90 (then it turns back on)
opinions?
Imagine;
opinions?
geposted Sat 06 Jun 15 @ 6:00 am
works great dog! but only one control? can you add a loop position knob? maybe? think of the possibilities...;)
geposted Mon 08 Jun 15 @ 7:43 pm
