I am fairly new to Dj'ing and running into issues with software. I have experimented my issues in a few different ways.
The Issue: When I load songs (it has been random, not the same ones every time) it freezes VDJ on my screen, but on my Numark Mixtrack I can still control whatever was playing before and sometimes part of the song that was downloaded but caused the error. This is quite alarming because in VDJ7 I never ran into that issue. Any help for a newbie would be much appreciated. Thank you.
geposted Fri 29 May 15 @ 9:49 pm
Are these songs you already have on a drive or stuff you are streaming?
geposted Sat 30 May 15 @ 3:29 am
Both. It has happened with the content unlimited stuff and my songs on my drive.
geposted Sun 31 May 15 @ 9:09 am
What build are you using?
Are you caching songs before putting them into a deck?
When a local song has an issue, do you have a CU song in a deck?
geposted Sun 31 May 15 @ 9:48 am
Excuse my lack of knowledge but what do you mean by build?
I do cache the songs first.
geposted Sun 31 May 15 @ 5:48 pm
And yes and no to the last question. It has frozen when I have both a local song, and a CU song. Same result with either scenario.
geposted Sun 31 May 15 @ 5:49 pm
In version 8, open the settings window. At the top will be the build number. Mine is 2282.
geposted Sun 31 May 15 @ 8:59 pm
