Topic: Playing songs already played in Automix
I noticed last week when I was djing for a Wedding , I had all the dinner music in the automix , I clicked the Automix mode button and enjoyed my dinner but then noticed the song that was just played , started again . This happened a few times so i had to turn off the automix and do it manually. SO is this a bug ?
geposted Fri 12 Jun 15 @ 7:33 am
blckjckPRO InfinityMember since 2008
Leo you have the "remove played" option selected?
Could it be that you had duplicate songs in your list?
Maybe the same songs with a difference in the title (two of the same song just tagged different)
geposted Fri 12 Jun 15 @ 12:12 pm
Is it possible that you selected "Repeat"?
geposted Fri 12 Jun 15 @ 3:26 pm
I will have to check my settings and let you know
geposted Fri 12 Jun 15 @ 6:54 pm
