Topic: Go to folder with external drive
Context menu > Go to folder isn't doing anything when the highlighted file is on an external drive.
geposted Sat 13 Jun 15 @ 10:53 am
Regression bug?
I'm not 100% sure because last time I checked was a couple of builds ago.
But I think that worked for me.
What I miss is: If you recurse any folder(s) you don't have a "goto".
geposted Wed 17 Jun 15 @ 4:40 am
Could be a regression, I'd imagine it would have been pulled earlier otherwise.
geposted Wed 17 Jun 15 @ 5:20 am
Tested with 2325, could not reproduce.
geposted Thu 18 Jun 15 @ 3:02 am
Perhaps you don't have My Computer listed as one of the root folders in the browser?
geposted Thu 18 Jun 15 @ 5:07 am
That could be the case. I
didn't realise there were conditions attached to that context menu
geposted Fri 19 Jun 15 @ 3:03 am
Basically it needs to be able to open the folder on the left side in order to show it.
If the folder can not be reached through the folder list then you can't show it.
geposted Fri 19 Jun 15 @ 5:24 am
What about this?
Could we get this?
geposted Fri 19 Jun 15 @ 6:29 am
Already there
geposted Fri 19 Jun 15 @ 8:07 am
Okay, that one was a bit confusing.
The "goto" option is missing as long as the folder is still recursing.
That is why I thought there is no such option. Apparently it took a while to recurse my whole drive :)
geposted Fri 19 Jun 15 @ 9:54 am
