i was doing a live mixshow my pc is over kill for this
mite want to fix that :)
i was just playing the track then the video went
geposted Fri 19 Jun 15 @ 1:43 am
specs
Windows 8.1
nvidia Gtx 760 6gb
i5 3570k 4.5 gthz
16 gb of ram
Windows 8.1
nvidia Gtx 760 6gb
i5 3570k 4.5 gthz
16 gb of ram
geposted Fri 19 Jun 15 @ 3:38 am
Are you able to reproduce this?
Does it happen with one specific video?
Did you have effects running?
Could your system have been too hot.
You really need to provide more information about issues and they are impossible to try and diagnose at the moment.
geposted Fri 19 Jun 15 @ 4:29 am
also u might try not overclocking your cpu while djing
geposted Fri 19 Jun 15 @ 4:51 am
Good call - hadn't noticed the overclock.
Unless it was a typo.
geposted Fri 19 Jun 15 @ 5:34 am
sry about that . no fx are on my pc is water cooled so its not that
geposted Fri 19 Jun 15 @ 5:40 am
true in most case's how ever i never had a problem with mixvibes cross at these speed .
also 4.5 is what my intel auto over clocks it self to
geposted Fri 19 Jun 15 @ 5:42 am
Have you overclocked you Graphics card? Is that water cooled also?
Have you been able to re-produce the issue?
geposted Fri 19 Jun 15 @ 6:10 am
the video card is air cooled . i dont overclock it as there's no need to .
the only time it overclocks it self is when im playing games
this is the 1st real go at mixxing video on vdj and im not sure whats going on
my cpu is the only thing thats water cooled by my own set up not a closed loop
under load im running 30 c
geposted Fri 19 Jun 15 @ 7:29 am
yes i have . i wish i could send a report of some sort .
im going to try reinstalling vdj
geposted Fri 19 Jun 15 @ 7:30 am
You're going to have to provide more information that that; I use a GTX760 in my primary dev machine with no issues and my gig laptop has a GTX770M again with no issues.
Try removing your settings.xml and retesting. If after that you can reproduce then please provide the information required for us to do so, along with other useful information such as the nVidia driver version, audio device and configuration, what type of files with what type of encoding, any effects or visualisations active etc - a lot more information than 'video locked up' because otherwise we can't help you ;)
geposted Fri 19 Jun 15 @ 7:40 am
i will try that
geposted Fri 19 Jun 15 @ 8:14 am
not sure why but it worked
geposted Fri 19 Jun 15 @ 9:08 am
