Beautiful skins, such as Zanard X-48 not compatible. Right turntable way off center and can not be corrected with the xml file.
Virtual DJ 8 severely screws up the 7 skins. Why is it not compatible? It also show transparencies bleeding thru, corners of squares rotating with the animations.
Many controls disabled in 8 that are needed, such as EQ, Effects adjust do not function, disabled rotating platters.
geposted Fri 19 Jun 15 @ 7:36 pm
Plenty v7 skins work in v8 but you should really use a skin designed for v8.
If a skin doesn't work, your best bet is to ask the author to update it.
geposted Fri 19 Jun 15 @ 7:57 pm
you are correct, I could ask them if they will be creating anymore for the 8. I just need to be patient and let it go for now, in time it will all get done.
Thanks for the reply.
Jon J.
Jon J.
geposted Fri 19 Jun 15 @ 10:57 pm
My apologies as it was not the fault of the Virtual DJ 8! It was the Zanard x-48 xml file that was at fault. He had a wrong value in the panel section.
I will not complain anymore as I was wrong and will not blame something that is not at fault.
The only excellent skin creator is Djdad he has them perfect for 7 and 8.!
I did get the Zanard x-48 fixed and it now works great in 8.
I will not open anymore topics against 8.
Jon J.
Jon J.
geposted Sat 20 Jun 15 @ 4:02 am
