Build 2334 states that:
Add string parameter "random" to video_transition_select to allow for a manual random transition selection
Can someone please explain how this works? For example I would like to exclude the pixelate video transition.
geposted Wed 24 Jun 15 @ 12:46 pm
If you want to exclude a transition from random, then do this:
* Open transitions selection list and pin it open
* Create a folder called Ignore
* Drag the transitions you don't want to be randomly selected into the Ignore folder.
The new command
The new command
video_transition_select "random"works exactly the same as the random video transition, but only does it once. This means you could select a new random transition if you don't like the one random selected, or you could disable random transition in options and change manually to a new random whenever you like.
geposted Wed 24 Jun 15 @ 1:57 pm
Thanks for your prompt response. Did you mean create a group as shown below? I cant see an option to create a folder
![](/image/51067/166208/Screen Shot 2015-06-25 at 11.48.04.png)
Secondly, if you meant create a group, I cant drag effects to that group:
![](/image/20952/166209/Screen Shot 2015-06-25 at 11.51.41.png)
Thanks
Thanks
geposted Thu 25 Jun 15 @ 3:52 am
Sorry, yes, I meant create a group.
What VDJ build are you on?
geposted Thu 25 Jun 15 @ 10:56 am
Hi,
Sorry for the delayed response.
Im on this build:
![](/image/20868/166333/Screen Shot 2015-06-28 at 20.17.40.png)
I cant drag video transition effects to a group. Can you?
Im on this build:
geposted Sun 28 Jun 15 @ 12:19 pm
Yes, but I will test tomorrow to make sure it is not a Mac specific issue.
geposted Sun 28 Jun 15 @ 5:32 pm
Hi, did you get time to check this out on a Mac?
geposted Mon 29 Jun 15 @ 9:15 am
Hi,
Yes, you are correct, it's not working in any of the effect selectors on Mac. I will have a look into why that is.
geposted Tue 30 Jun 15 @ 4:00 am
Thanks for confirming.
geposted Tue 30 Jun 15 @ 8:42 am
Will this get addressed soon?
geposted Wed 01 Jul 15 @ 9:45 am
