VDJ REMOTE ANDROID FAILS TO CONNECT VER 8.0.2334 RIGHT OFF THE BAT, IT SEE'S MY FONE (DISPLAYING THE PHONE NAME) SO A MANUAL ADDITION OF THE IP ADDY WILL CONNECT.
ONLY FAULT I FOUND BESIDES THIS MAJOR 1 IS U HAVE TO RECONNECT WITH A DIFF IP ADDY IF U LOOSE CONNECTION, THEY SHOULD PAIR FOR GOOD !! FAIL
VDJ REMOTE RUNNING V7 WILL SEE EACH OTHER AND CONNECT, (NEED TO PAIR FOR GOOD USELESS DOING THIS ALL THE TIME)
I CHANGED THE STANDARD SKIN TO THE MULTITOUCH BY DJ DAD AND MESSED THE CROSSFADER MAPPING WITHIN MINS OOOPS :(
PROB NEEDS A REINSTALL
geposted Wed 24 Jun 15 @ 1:09 pm
DID YOU INSTALL APPLE BONJOUR ON YOUR PC?
geposted Wed 24 Jun 15 @ 1:43 pm
Please don't post all in caps.
If you're on PC, then you need bonjour installed for automatic detection. You need it on a Mac too, but it's supplied by default there.
Once bonjour is running, they will connect automatically.
Quote :
HOWS THIS MENT TO WORK IN A CLUB, WOULD IT WORK UNDER TEATHERING THE LAPPY TO THE FONE ??
THIS IS A MAJOR FLOOR, I HAVE A PROGRAM CALLED TEAMBUILER FOR REMOTE CONTROL/VIEWING OF MY LAPPY CUS IM LAZY FOR CUEING FILMS LOL THIS CONNECTS REGARDLESS OF NETWORKS CANT YOU INCORPORATE THIS FORM OF CONNECTION ??
We are not going to be introducing a teamviewer style connection, and no, it's not a major flaw at all.
The application very very very clearly states it needs a Wi-Fi connection, which includes tethering.
geposted Wed 24 Jun 15 @ 2:19 pm
Alos, teathering with IOS is very locked down. That is an Apple iPhone problem. Not the fault of this application.
geposted Thu 25 Jun 15 @ 11:06 am
