Forum: Old versions
Topic: VDJ8 not reading folders
Hi everyone, my VD8 is not reading some folders on VD7 read all the folders
geposted Thu 25 Jun 15 @ 10:36 pm
Any help please
geposted Thu 25 Jun 15 @ 11:58 pm
Could you be more specific ?
what kind of folders ? Normal , Virtual, Filter ones ?
What do those folders contain ?
Do those folders show up in the Folders tree ? If they do ,are those empty ?
Screenshots may help too.
geposted Fri 26 Jun 15 @ 12:31 am
normal folder on my external hardrive
geposted Fri 26 Jun 15 @ 12:09 pm
geposted Fri 26 Jun 15 @ 12:22 pm
are those Karaoke files ?
If they are, then goto Settings-->OPTIONS tab and enable "Show Advanced Options"
Then search for the setting "ShowZipKaraoke" and make sure its set to "Yes" (default value)
If it was to Yes, then check on the left side Toolbar of the Browser for Browser Options -->Show Only (a small round dot button) and make sure all 3 of the options are disabled.
geposted Fri 26 Jun 15 @ 6:25 pm
all videos files and what i did i make a new folder and move thos videos and now i'm able to see them but i'm goint to all my folders one by one create a new folder and moving the videos i think is something with the folders access because in VDJ7 i dont have the problemwith any folders
geposted Mon 29 Jun 15 @ 1:41 pm
