Hi All,
I inadvertently pressed Restore Factory Default. Now I cant get anything to work as it should. I've tried using my last good back up of all the VDJ files to no avail. Volume sliders up at full, only left channel working, when i select a song for deck 2 it cuts off deck 1..... at my wits end with a gig tonight.
I'm running latest build VDJ on PC with a Denon MC6000 controller. Help, suggestions all most welcome with 3 hours to go before I leave for work.
Thanks in advance...
geposted Sat 27 Jun 15 @ 8:05 am
please have a look in VDJ Root Folder/ Mappers
if you did a custom mapping, it should be stored there
geposted Sat 27 Jun 15 @ 8:55 am
I just removed the mapper and it works with the native one. Will try my back up mapper now and see what happens. Thank you for your reply.
geposted Sat 27 Jun 15 @ 8:57 am
