Thanks for the Volume bug fix with the 2345 update. Now when I load the same song it will play on deck 1 & 2 at the exact same volume levels. Thank You for this fix.
Jon J.
Jon J.
geposted Wed 08 Jul 15 @ 4:15 am
There you are, I was going to support your post about the volume issue. I too was having the right deck volume spiral out of control, but now both decks volumes are even.
geposted Wed 08 Jul 15 @ 1:36 pm
Thank You DJ Bertie, they did not seem to believe me, but I had tested it on 3 brand new different Laptops and had that Volume Bug
But I think that the problem has come back again. The first few time of loading the songs, it was even. Now it is doing it again. I have to double click the gain controls first to get the same volume levels from both Decks. Maybe they will look into to fix that returned Bug.
Have a Great Music Day.
Jon J.
Jon J.
geposted Wed 08 Jul 15 @ 7:06 pm
Yup, the problem came back again for me too. Like you said, the first few songs were fine then the right deck started spiraling out of control again.
geposted Sat 18 Jul 15 @ 12:42 pm
