If playing a track whose tempo is variable and therefore has beat anchors throughout, playing a looped sample over the top which has Sync-Lock set will produce noticeable crackles and pops.
This doesn't happen with a regular tempo track i.e. no beat anchors or with a variable;e tempo track and the looped sample set to Sync-Start.
geposted Sat 11 Jul 15 @ 4:14 am
In the latest build 2363, this issue is better however, the samples can go out of time with variable tempo tracks. I haven't seen this issue on regular tempo tracks.
Please check this video: http://youtu.be/4zvQoixpCbI
You can see in the initial section that the CBG is in line with the beat.
00:33 the drum sample begins to play over the top of the track in time.
00:48 you hear a bit of a drop out, but the timing remains OKish.
00:53 a drop out but note the timing goes out.
01:03 I stop the sample and restart, it syncs back up in time.
geposted Thu 30 Jul 15 @ 5:01 am
Video is set to privat.
geposted Thu 30 Jul 15 @ 6:21 am
Doh! Fixed now... Have just noticed though it can't be view in Germany... Is that a problem?
geposted Thu 30 Jul 15 @ 6:43 am
It takes approxymately only a few seconds to get the video running ;)
EDIT: Holy sh**... that are a lot of anchors you set there. Must have taken you hours...
geposted Thu 30 Jul 15 @ 12:32 pm
Lol, yeah... I have several hundred tracks like that, it's an OCD thing... Been working on them for a couple of months... :-)
geposted Fri 31 Jul 15 @ 5:58 am
