I have asked this before but I have not gotten an answer yet. Virtual DJ 7 had a great feature for us DJs to manually adjust the length of the Auto Mix (fader) Feature. It used to be called Auto-Cross Length and it was a slider we used to adjust manually under the Configurations - Options Screen. With this feature we were able to map a key to do a crossfader function to perform a Cut Mix (and immediate cut from one deck to the other instead of a slow transition from channel to channel) This feature was taken away on Virtual DJ 8. On virtual DJ 8 we only have a cross fader curve selection which is not the same. I can send you a screen shot of the specific feature Im referring to if that helps identify the actual location of it.
Please Help.
Please Help.
geposted Sat 11 Jul 15 @ 4:39 pm
Since build 2325
"automix skip/mix_now length can be customized (automixSkipLength option)"
geposted Sat 11 Jul 15 @ 5:33 pm
Also as it's a setting you can script it to a dial (custom or hw) for full otf control.
Something like
Param_multiply x (x being maximum length) & setting "automixskiplength"
Something like
geposted Tue 14 Jul 15 @ 6:46 am
