Topic: Continual Freezing - Build 2348.1029
pntballControlleristMember since 2012
I search for a song, find it and play. Next song I search for, drop or click to play it - it shows the song title and artist in the deck but nothing happens, never loads. I attempt to quit and it freezes completely - requiring a force quit.
I did not have this issue in the prior version...
geposted Thu 16 Jul 15 @ 9:37 am
Haui70PRO InfinitySenior staffMember since 2008
You do not use a Content Unlimited track, right?
When the problem occours, please try to load a different track then the one you have loaded on the deck.
When the other track has loaded, please try to load the initial track again.
Does it work?
geposted Thu 16 Jul 15 @ 2:07 pm
