Up until a few weeks ago (unfortunately I do not have a build or more exact timeline) the LEDS that light up depending on the masterdeck's BPM only follow deck 1. Doesn't matter which skin or how many deck skins I use. Example : say deck 2 is loaded with a 128 BPM track and has the masterdeck "M" on and deck 1 isn't loaded, the LEDS will follow deck 1's pitch slider. Since it worked perfectly up until recent I did a fresh install with no success. I'm I missing something?
Please see link "http://www.virtualdj.com/forums/189710/General_Discussion/_SOLVED__LED__on__with_BPM_variable__.html"
geposted Sun 19 Jul 15 @ 8:06 am
The offered action in the other thread does not take the Masterdeck into account.
Try this..
masterdeck ? param_bigger 125 get_bpm ? on : off : off
It should work for Leds that exist on both sides of your controller/skin.
If its a single Led, then you need to query and find which deck is the masterdeck.
Try this..
geposted Sun 19 Jul 15 @ 4:00 pm
