Topic: Bug on search data base
Hi guys, I have just purchased my copy as I am going mobile soon. I had a problem when testing the equipment out the other day... Every time I loaded up my external hard drive before and search in the DB all tracks I need were there even if not use before. However since last update I have noticed when searching I have nothing and I have to Recurse the drive. Any ideas please?
geposted Mon 20 Jul 15 @ 6:46 pm
Go to virtual dj settings options (have the advanced settings always checked) type in the search box searchdb is it set on auto? if you set it to not automatically read your songs then it will read only what you manually add ( i prefer it that way). This answer could be found on the vdj8 manual as well.
geposted Wed 22 Jul 15 @ 3:42 am
