ok I just bought a new laptop alienware windows 7 video card Nvidia Geforce GTX 980M I copied all my same settings from my previous alienware which had a GTX 675M windows 7, issue im having everytime I load Milkdrop8 as a option in VideoAudioOnlyVisualisation I go to load a video on deck or song don't matter and once I drag song in deck screen goes dark grey and black and gets fuzzy and will stay that way for awhile then if I undo milkdrop8 option and leave in none in option and load song or video again VDJ8 skin stays normal doesn't change colors, skin im using is VirtualDJ 8:2 Decks any help would be great because I really would want to run milkdrop in background if this issue is resolved
geposted Mon 20 Jul 15 @ 9:35 pm
maverick77014 wrote :
..copied all my same settings from my previous alienware ..
If you mean the settings.xml from VirtualDJ folder, then this is not recommended.
If you remove the settings.xml file (move to a Backup folder) and launch VirtualDJ again, do you get the same issue ?
geposted Mon 20 Jul 15 @ 9:39 pm
let me try that
geposted Mon 20 Jul 15 @ 10:08 pm
no same issue I removed setting.xml and same issues occur but now seems to be flashing
geposted Mon 20 Jul 15 @ 10:10 pm
You have the latest v.1.3 for Milkdrop , right ? http://www.virtualdj.com/plugins/index.html?category=effects&search=milkdrop
And the drivers for your video card updated too ?
geposted Mon 20 Jul 15 @ 10:28 pm
ok heres what I just did I deleted VDJ8 from laptop but kept everything in backup folder reinstalled milkdrop8 from vdj site reran test same issue happened I had sonique vidz saved in backup files loaded those in plugin and ran in videoaudioonlyvisualisation releaded songs and videos and no issues everything fine skin didn't go haywire or anything only does it when loaded milkdrop
geposted Mon 20 Jul 15 @ 11:01 pm
just checked update on driver all up to date
geposted Mon 20 Jul 15 @ 11:09 pm
Install this:
https://www.microsoft.com/en-gb/download/details.aspx?id=35
Make sure your videoFPS setting in VDJ is 30 too (the default).
geposted Tue 21 Jul 15 @ 10:04 am
Thanks I'll try that right now...
geposted Tue 21 Jul 15 @ 11:20 am
SBDJ what exactly am I downloading from that link?
geposted Tue 21 Jul 15 @ 1:34 pm
DirectX9 if I'm not mistaken.
geposted Tue 21 Jul 15 @ 1:53 pm
thanks SBDJ that was the problem once I downloaded that link and installed it, no more issues and milkdrop works great...
geposted Tue 21 Jul 15 @ 1:58 pm
