I am experiencing some difficulties... I want to record using my controller (Numark Mixtrack 3) which comes with Virtual DJ LE. The trial for Pro edition recently ran out and since then, when I go into the settings I cannot record or adjust any other settings apart from my audio or licences... Is this normal with this controller? If I purchase a Pro License for $99 for this controller, will I be able to record and access all features?
Thanks!
Thanks!
geposted Sun 26 Jul 15 @ 1:19 pm
In the MASTER center panel, there should be a REC button.
In the LE mode, you cannot change the path or the filetype for the recording file, but certainly you can record your mix
geposted Sun 26 Jul 15 @ 1:34 pm
