I'm trying to run Virtual DJ 8 on a Windows PC. Every time I load the program, I can only see the top left corner of the program; everything else is black. Randomly clicking on the black part of the screen allows me to still interact with the program; I just cannot see what I'm clicking.
Any ideas about how to fix this? I recently upgraded to Windows 10. Could this be part of the problem?
Thanks!
Thanks!
geposted Wed 29 Jul 15 @ 12:28 pm
Ensure your display drivers are installed; you likely only have the basic display drivers supplied by MS, which won't allow VDJ8 to run.
geposted Wed 29 Jul 15 @ 2:01 pm
While its possible its a win10 thing, you could also check if you're using an external monitor??
There was an issue where if youre using video out, you need to set a video option like this:
Options > Advanced (tick) > video > videoForceFullscreen set to 0
it was reported a few times where when starting v8 the skin would appear very zoomed in.
geposted Thu 30 Jul 15 @ 8:17 pm
I ran into this problem with an atom machine it was the correct display driver causing the problem, with some messing about (switching skins) then that driver crashed and the default m$ driver managed ok
geposted Sun 02 Aug 15 @ 9:55 am
