Beat Keeper Visual Display Jumps one Beat. It will display across or vertical for the count of four times smoothly. It is not flowing in it's counts as VDJ 7 does. I had noticed this way back in the earlier builds also. I will try to give the example the beat keeper VDJ 7 = 1-2-3-4-smoothly then back to 1. VDJ 8 should be smoother but is jumps at 1&2 then 3 &4 is back to a smooth flow LED light display visuals.
1,2-3- 4 this is for sure core code that has been changed in VDJ 8 this jump of beats 1 &2 does not seem realistic and should be fixed or updated to work like it did in VDJ 7.
Jon J.
Jon J.
geposted Thu 30 Jul 15 @ 2:37 pm
My apologies I was wrong it is not the VDJ 8 Code it is the XML and Bitmap files that are causing this weird effect.
Just ignore this post.
Jon J.
Jon J.
geposted Fri 31 Jul 15 @ 11:37 pm
