I reported this issue six or seven months ago and it was 95% fixed until now when it has reappeared. My auto mix settings are as follows:
Type: Fade (remove into/outro)
Length: 0s
The problem is that on certain files, very rarely the same files, I notice that the auto mix start cue point is too far to the right on the file waiting to be played. If I go to POI Editor the cue point will not move on the waiting deck. If I go into BPM Editor on the waiting file and click on either /2 or x2 the cue goes to the normal position. If I reanalyze the track nothing happens. This will happen when a short file 5 to 40 seconds is waiting but the same file will be fine with a different file preceding it. This is sporadic and kind of defeats the purpose of auto mix if I have to constantly check to see if the start cue is right. What the BPM has to do with this is a mystery to me but it definitely is the cure. What the heck is going on????
Length: 0s
geposted Thu 30 Jul 15 @ 6:23 pm
