This is the 2nd time that I have reported this problem here, and I do not want to cause duplicate reports.
This is a better more clear example of this bug.
Will this eventually get fixed so the Shell Icons will show correctly? Much nicer looking when they do, cleaner looking skin layout.
geposted Mon 03 Aug 15 @ 6:31 pm
Just an idea.
Can you reproduce that with the standard v8 skin?
It seems that you are using a v7 skin.
geposted Tue 04 Aug 15 @ 2:45 am
Yes VDJ 8 does this with all skins, and also the standard default skin. All PCs are affected with this issue.
VDJ 7 does not have this problem
Thanks.
Jon J.
Thanks.
Jon J.
geposted Tue 04 Aug 15 @ 1:57 pm
Shell icons still come and go. There is a new folder that has appeared called Musics and there is a double listing of my recorded tracks. I cleared the settings folder but it is still there. I do not have a folder anywhere on my laptop called Musics,
I have my Music in my documents and settings. Where did the Musics folder come from? When I unfold the Musics folder then my music is listed again along with a duplicates of my recorded tracks. and the shell icons try to partially show up there, but not in the upper my music folder, they are all just the plain white icons and are duplicates of my music folders
Jon J..
Jon J..
geposted Sat 08 Aug 15 @ 5:43 am
