Latest build
Osx 10.7.5
Mbp i7 2.9ghz 8gb
https://www.youtube.com/watch?v=4Hjc9UrIS90
Osx 10.7.5
Mbp i7 2.9ghz 8gb
geposted Fri 07 Aug 15 @ 8:45 pm
I'm not sure what this is, but it isn't a bug report...
geposted Fri 07 Aug 15 @ 8:54 pm
on my second MBP same osx same build
https://www.youtube.com/watch?v=OZ68rxSLZkU&feature=youtu.be
geposted Fri 07 Aug 15 @ 9:15 pm
Could you try describing your issue?
I can't make anything out from those videos.
geposted Sat 08 Aug 15 @ 1:47 am
Deleting the favorite folder vdj closes
Deleting a song from the browser vdj closes
After 5 times that the vdj closes the favorite folder is still there...
I never had something like that on my dell and win 7.
geposted Sat 08 Aug 15 @ 2:29 am
It's a Favorit folder, isn't it?
geposted Sat 08 Aug 15 @ 8:05 am
Before you are deleting the folder or the track from VDJ..........did you actually delete the folder or track from your computer using your OS?
In other words, does that folder location still exist outside of VDJ? Does the track still exist on your hard drive outside of VDJ?
Maybe if you are deleting the folder/track first (outside of VDJ) then trying to remove it from VDJ, that is causing the problem.
geposted Sat 08 Aug 15 @ 11:17 am
Yes
Groovindj i just wanted to delete them thru vdj same as i do on my pc, is there another way to delete the favorite folder not thru vdj ?
Its a simple supposed to be a simple thing for the software...
geposted Sat 08 Aug 15 @ 12:21 pm
any suggestions are welcome...
geposted Sun 09 Aug 15 @ 8:44 pm
i don't know where they are stored on the mac but on PC they are under /documents/virtualdj/folders/
look for files with this extension ".vdjfolder" you should have one for each of your favorites, virtual folders, and filter folders
hope this helps for now
geposted Mon 10 Aug 15 @ 12:51 am
