I've just stumbled across this perplexing bug with VDJ 8 & Windows 7. Usually I use an external sound card but whilst ordering playlists I switched to the laptops internal soundcard which I enabled on its default 192KHz Sample rate. This meant that a 4.04 Min WMA song was shortened to 3:30 as it loaded and the database song duration was similarly shortened. Loading something else on the deck and then doing another reanalyze returned the correct length before it screwed up again on loading. VDJ 7..4.2 isn't affected by this and I tried the following builds which all had the problem, some shortening the duration to 2:30:
1932
2162
2348
2369
The workaround is to ensure the sound card is set to 44.1KHz
1932
2162
2348
2369
geposted Sat 08 Aug 15 @ 11:35 pm
Would it be possible to send this wma file to me?
It does not happen with the wma files I have here.
geposted Sun 09 Aug 15 @ 7:57 am
