I have turned off the cover downloads and it still downloads all of this junk that does not pertain to my music files. I do my own customized cd covers and chose them manually and this still happens. This is very bad as it uses up my hard drive space. I was up to 150 mb.
How do I get it to stop this junk downloads?
geposted Tue 11 Aug 15 @ 4:24 pm
So you cleared the folder before disabling automatic cover downloads?
Probably these are cached files from the cover art selection window then, which also shows you online options.
geposted Tue 11 Aug 15 @ 4:34 pm
Yes I cleared the cache and it still persists in doing it's thing anyway. When I go to the tag editor and select from a file it downloads other stuff that I do not want. It needs it to stay clear of showing me other cover options from google and Itunes. When it show the other download options it downloads what it sees by it'self automaticly. It is also downloading music lyrics. and not related relevant files.
What would happen If I delete its cache folder completely? Can I still put my custom covers in?
Why will it not stop when I have in the options do not download covers?
Thank You so very much for your help. You DJ Artists are the best there is!
Jon J.
Jon J.
geposted Tue 11 Aug 15 @ 4:52 pm
