Right side graphics interface windows. Why is there no command for the side view list as there is for the effect_show_gui?
It would be good to have the option to create a button that opens the sidelist options.
I have tried every command possible and they do not open the right hand side list.
Example
rightclick="sampler_bank 'sideview' on ? sampler_bank 'sideview' off : sampler_bank 'sideview' on"
sideview 'automix', sideview 'sidelist', sideview 'sampler', sideview 'karaoke', sideview 'clone', sideview ", sampler_bank -1, sampler_bank +1, sampler_bank ', sideview_triggerpad, karaoke, automix, effect_dock_gui, effect_show_gui, effect_active, effect_button, search
None of these commands work in VDJ 8 as a custom push button.
Thank You.
Jon J.
Example
Thank You.
Jon J.
geposted Sun 16 Aug 15 @ 2:06 pm
geposted Mon 17 Aug 15 @ 8:50 am
Thank You PachN very much! :) It works!
Just that simple indeed! What I wish for from VDJ is a complete SDK of all of the commands that are scripted for the VDJ 8.
I did put that in my wish list.
I have checked all of the available SDKs and they are not helpful for what I am looking for.
Thanks again.
Jon J.
Thanks again.
Jon J.
geposted Mon 17 Aug 15 @ 5:05 pm
There is a wiki page with all commands
http://www.virtualdj.com/wiki/VDJscript_verbs_v8.html
geposted Mon 17 Aug 15 @ 6:50 pm
That Works! You guys are awesome!
Thanks again and again!
Jon J.
Jon J.
geposted Mon 17 Aug 15 @ 7:02 pm
